  1. DECEASED
    Jun 2009
    Heaven
    Dear Google, please swallow this:
    "In order to show you the most IRrelevant results,
    we have omitted some entries very similar to the NNN already displayed."
    Originally Posted by Google
    Did you mean: "In order to show you the most relevant results"
    Your search - "In order to show you the most irrelevant results" - did not match any documents.
    2)
    Yes, your name is 佐々木 希 (or Nozomi Sasaki)
    3)
    compilar essa buceta
    compilar esta buceta
    Last edited by El Heggunte; 10th Apr 2016 at 07:10. Reason: because Google is stubborn >_<
  2. DECEASED
    Jun 2009
    Heaven
    Yet another image:
    Originally Posted by gbblanch View Post
    Originally Posted by mr270368 View Post
    There is a Quality setting just above video options, It is set at 'same as source' by default hence your massive avi. Change this to custom and your own settings will be used when encoding.
    OK, that answered my question. My 12 MB "test.avi" file turned into 38 MB with Quality set to "same as source". I set it to "normal" and it went down to 16 MB and I couldn't see any difference in the on screen quality.
    My logic was flawed: I saw "same as source" and thought "if the source is compressed, the output will be as well" and for some dumb reason I didn't think of trying the other settings. Thanks for solving the mystery for me.
    test
    test
    testing again
